Carver ZR1600 schematics
0 Members and 1 Guest are viewing this topic. Read 2923 times.
tomahack
« on: 8 Apr 2005, 05:49 pm »
I'm looking for the ZR1600 schematics. My goal is to find the easiest way to bypass the input module. Any help would be VERY appreciated.
Gordy
« Reply #1 on: 9 Apr 2005, 03:06 am »
Have you seen Monolith's old thread?  http://www.audiocircle.com/index.php?topic=5413
tomahack
« Reply #2 on: 11 Apr 2005, 07:45 pm »
Quote from: Gordy
Yes. But it's an old thread and it is not clear to me as where exactly are the insert points on the PCB.
Gordy
« Reply #3 on: 14 Apr 2005, 07:25 pm »
If you're just removing the input module and not trying to bypass the opamps the easiest thing to do is tap into the ribbon cable connector on the main board.  Use  pin 20 for CH2+, pin 18 for CH2-, pin 16 for CH1+ and pin 14 for CH1-.  A big thanks to Nathan Loyer who gave me this info  :D
