Goodman Dimensions 8 refurbishing
0 Members and 2 Guests are viewing this topic. Read 4608 times.
Doublej
Re: Goodman Dimensions 8 refurbishing
« Reply #20 on: 5 Aug 2022, 06:44 pm »
Looks great. The crossover purists will tell you to ditch the metal screw holding down the inductor and use something non-magnetic. Often a zip tie is used. They will also tell you to ditch the circuit board and wire the components together directly.
YMMV
Boris71
« Reply #21 on: 6 Aug 2022, 05:23 pm »
Just wanted to let you guys know: they sound fantastic!
The spare tweeter was not necessary, the cap change solved all tonal issues and the Goodmans made it in my listening room.
JCarney
« Reply #22 on: 6 Aug 2022, 06:30 pm »
Congratulations and well done, they look great. May you get many years of joy from them.
JCarney
