Bad optical input on Vision DAC?
0 Members and 1 Guest are viewing this topic. Read 2171 times.
dlparker
  • Dave Parker - KC, MO
« on: 15 Jun 2022, 10:09 pm »
I've got a Vision EC DAC and one of the optical inputs has gone bad. Given the quality of Frank's gear I can't help but think it's something I've done, but I have no idea what it could be.
Any ideas of what I could have done or whether there's a simple fix? Simple being something like spraying some compressed air - which I'm out of and just ordered more of - into it .
WGH
Re: Bad optical input on Vision DAC?
« Reply #1 on: 15 Jun 2022, 10:25 pm »
Cables can go bad too
dlparker
« Reply #2 on: 15 Jun 2022, 10:27 pm »
I plugged the same cable into the other optical input and it works fine. Been listening using that one for the last few hours
avahifi
    • http://www.avahifi.com
« Reply #3 on: 16 Jun 2022, 11:17 am »
The best way to get a prompt response from me is to email me directly at: [email protected]
We will need to see your DAC to repair it.
Please call me at 651-330-9871 for more help.
Frank
dlparker
« Reply #4 on: 16 Jun 2022, 08:50 pm »
OH NO! Then I'd be without it! If I can get a sub I'll that.
Thanks Frank!
dlparker
« Reply #5 on: 19 Jun 2022, 04:50 pm »
Problem solved! Sprayed some compressed air in there and now it's working fine.
PSB Guy
« Reply #6 on: 19 Jun 2022, 07:22 pm »
This is good to hear, both for you and for possible future reference.
dlparker
« Reply #7 on: 19 Jun 2022, 07:30 pm »
And the NEXT best thing (#1 of course - it's fixed) is that I don't have to send it off and be without it.
avahifi
« Reply #8 on: 20 Jun 2022, 01:08 pm »
Great fix!  I would not have thought of that.
Better yet, now your system has more air.  :)
Frank
dlparker
« Reply #9 on: 20 Jun 2022, 03:13 pm »
Frank
It didn't have enough breathing room. Now my whole system is a little more open and airy! (Two can play this game!)
