Pair of LCY-100K-MK2 Top Mount Supertweeter / Ribbon tweeters SOLD
0 Members and 1 Guest are viewing this topic. Read 898 times.
joessportster
  • Set & Single Driver Bliss
Wonderful Tweeters, Used for approx 50 hours comes with original packing and paperwork. As New. I found these much nicer than the Fostex supper tweeters, Not as in your face or piercing. Adds a great top end and air to pretty much any existing speaker and with the built in Attenuation and crossover points its easily adaptable
Best REASONABLE offers considered
Madisound description
LCY-100K-MK2 TOP MOUNT SUPERTWEETER
Top mount ribbon tweeter, 91-93dB/2.83V/1m, 8 Ohms.
Dimensions : 90mm wide x 147mm length x 98mm height
Twin-Ribbon tweeter technology
Extra high frequency response
Excellent vertical and horizontal pointing characteristics
Parallel multi-wiring OFC transformer
Aluminum shell case
Precision design crossover built-in
Simply plug and play
The LCY Ribbon tweeter is based on technology well proven by audio pioneers for over half a century but is innovatively designed to satisfy the sophisticated demands of the digital era.
The LCY tweeter has a unique design employing twin ribbons of half the length of conventional ribbons in order to control vertical plane dispersion. Thus it reproduces both vertically and horizontally as effectively as voice-coil operated dome tweeters but with the accuracy, elegance and refined timbres of ribbon-tweeter technology. Magnetic flux density is enhanced by the use of our own neodymium magnet system and a sophisticated transformer with parallel multi-wiring OFC has been adopted for superior frequency and power handling and optimal size.
Model LCY-100K-MK2 has been designed specifically bearing in mind the audiophile who already owns a good speaker system and simple to operate and use. Simple put it on the top of the matched speaker, connect the high quality cable in parallel with the terminals of the speaker, and then adjusting the two switches on the rear panel, confirm the best crossover point and output to getting the great matching with its main speaker.
- Frequency Range: 10KHz ~ 100KHz
- Sensitivity: 91dB ~ 93dB (2.83V / 1M)
- Impedance : 8 ohm
- Built-in crossover : -18dB/oct
- Crossover frequency: 10KHz / 13kHz
- Magnet type: Neodymium
- Case material : Aluminium
- Nominal power handling: 200W
- Weight : 1.46Kg /pc
Link: https://www.madisoundspeakerstore.com/super-tweeters/lcy-100k-mk2-top-mount-supertweeter-each/
300.00 for the pair Buyer covers fees and shipping.  Pics are actual drivers offered and from my add on another site
« Last Edit: 11 Jun 2022, 10:12 pm by joessportster »
joessportster
SOLD
