0 Members and 1 Guest are viewing this topic. Read 3569 times.
Moral of the story is to get your room treated and save yourself a lot of frustration with putty adjustment. Putty is a PITA but you get fabulous result with right room acoustics. I wouldn't do with out either of them...
You can dial in speakers in an hour but it's only 90% imo. You need to listen to a wide variety of music at various room positions. To me a half inch is significant and until I've used up all the possibilities of room position I'm not satisfied I've done the best I can. It wouldn't matter to me what brand of speaker it is I'd still take the time to move them a little here and there all the while having a wide variety of music listened to. The fact that some people have problems I feel is for two reasons: ...
Once the speakers broke in, it was obvious their sonics had changed. So, a third crack at tuning was neccesary, and this time it took only 45 minutes (after re-applying some of the putty to each speaker. I have not touched them since - over 2.5 years ago. My system hasn't changed (and hopefully won't for another decade or so). Oh, when folks let me try out gear, I'll modify the potentiometers to allow fine-tuning. But, I put them back where they started when my gear is back in the loop. I'm a firm believer in taking the time to do it right the first time. But once they are where I like them, I just want to sit back and enjoy the music. In my listening room, my ears are the only ones that matter. ...
I think part of the key is you don't boost dips, only flatten peaks. Yeah that kills a bit of sensitivity but with active setup that shouldn't be a problem. You still need to deal with nulls in a normal fashion.
