0 Members and 1 Guest are viewing this topic. Read 9179 times.
Dan Wright has a new one in process. I'm sure it will be top notch like all of his gear.
I'd suggest going with your initial idea of buying a tube preamp. A buffer adds an unnecessary component in the chain. A decent quality tube buffer won't be cheap, plus once you spend money on upgrading the power cord and the interconnects, you'll arrive at the cost of a good tube preamp. Besides, components that don't contain kick-ass power supplies will be quickly replaced. Been there, done that...
I am thinking of the buffer as an alternative to the pre. This is partially a result of me planning out an SP14 build and realizing how separate the volume and attenuation really is from the active tube section.
If you are willing to consider a tube pre, I settled on the 1 below. I put some expensive tubes and caps in it but this can done over time. The power supply is located in the bottom of the unit and therefore separated from the circuit. It is surprisingly good. Really surprised me once it arrived.
The MP gear is no joke. I had their DAC in here a while back and it sounded (and measured) excellent. Build quality was impressive, too.
