0 Members and 2 Guests are viewing this topic. Read 3776 times.
I suspect the effect being heard is "relative position in the recording room and mic". The reason I am phrasing it that way is that the likely effect you can get is:sound happens at sourceit directly travels to the microphones sound from source also hits a ceiling first reflection and bounces down to the mics with a delay.When you hear playback with the little recorded delay, your mind attributes it to height as it never wants to think it is closer to the floor, and as the left /right info is coming from the stereo effect.That is all a lay-guess
The original mic didn't just capture soundstage information in 2 dimensions, it captured it in 3. So when playing back through the speakers, the soundstage is left/right as well as top/bottom. Although, IME the top/bottom information is a bit weaker than the left/right information.
With speakers that emit sound only to front soundstage reproduction becomes severely limited (2D soundstage) for bests results try planars or OBs.
This is not my experience.I have owned both planars, and OB's, and loved them. I currently own a standard 3 way system; Jeff Bagby's "Auricle" monitors, sitting on a pair of his 10" woofer modules(these are not subwoofers), and my soundstage is huge. in all directions. These have RAAL riobbon tweeters, and SB Acoustics "Sartori" mids and woofers. Percussionists in orchestras sound as if they are coming from behind the rest of the musicians, and 25' back in the soundstage. Many instruments come from well beyond the outer edge of my speakers. My soundstage is very close to being as large as the planars and OBs I've had in the past.
A miracle, you was blessed by a miracle, it even dont have drivers firing backwards and have deep soundstage, however sound stage wide depend on the room width and speakers distance each other.
Getting good soundstage height is also one reason I like tall speakers.
Was the sarcasm button depressed? Not sure.
