Question about series-parallel
0 Members and 1 Guest are viewing this topic. Read 1072 times.
« on: 27 May 2022, 06:27 am »
Does, for example, having four equal driver's running series-parallel have any differences if the are ran parallel-series. They both come out to the same impedance, but is there any other intended or unintended changes?
Re: Question about series-parallel
« Reply #1 on: 27 May 2022, 10:58 am »
Both will have the same final impedance with different values:
8 + 8 / 8 +8 = 8Ω
8 / 8 =4, 8 / 8=4, 4+4= 8Ω
In my experience in pro-audio and hi-fi S-P or P-S connections are a great solution to speakers bands regularly use in stage or PA, but are not suited to hi-fi however its used in home audio too when 16Ω woofers are not available.
The prob with S-P or P-S is that these connections create reactance/inductance even in low SPL and the impedance will drop wildy at high SPL, I didnot know that but soon discovered why my ''robust'' Hartke bass amp blow a diode driving a 4x10 cabinet. :duh:
« Last Edit: 27 May 2022, 10:40 pm by FullRangeMan »
