Synergy
0 Members and 1 Guest are viewing this topic. Read 3695 times.
Auro
Synergy
« on: 22 May 2022, 10:23 pm »
Hello everyone,
I would appreciate all info regarding synergy between Odyssey amplifiers and ATC speakers.
What amp do you drive your ATCs?
Is it mono or stereo configuration?
What preamp/DAC do you have?
What signal cable and speaker do you use?
Is it bi-wired, perhaps tri-wired?
Etc.
Peter
Auro
Re: Synergy
« Reply #1 on: 22 Jun 2022, 11:54 pm »
C'mon folks :)
It'd be very interesting to hear about how matches Klaus' amps with ATC speakers...
opnly bafld
Re: Synergy
« Reply #2 on: 23 Jun 2022, 01:47 am »
It's possible that no one has both (at least on AC).
qdrone
Re: Synergy
« Reply #3 on: 7 Aug 2022, 05:32 pm »
I don't have that configuration but if you want to see what I drive my Odyssey Liquids with,click system. I prefer silver speakle cable and Copper inter connects and power chords.
Dishman442
Re: Synergy
« Reply #4 on: 10 Aug 2022, 10:34 pm »
Tell me about your ATCs. I am not knowing.
Auro
Re: Synergy
« Reply #5 on: 20 Aug 2022, 06:48 pm »
Klaus said he has quite a few customers who have the combo and the feedback is awesome.
I'd hear them about the rest of their components, matching speaker cables, etc.
Maybe they aren't on Audiocircle, though...🤔
hi_watt
Re: Synergy
« Reply #6 on: 8 Sep 2022, 03:23 am »
I just left Klaus a voice message on possibly having my Khartago's upgraded to accomodate my passive ATC SCM 40 speakers, that are 85db. The amps powered Revel F206 speakers before, which were 88db.
The ATCs sound great, it just feels like they need a bir more push, as they are power hungry.
jjss49
Re: Synergy
« Reply #7 on: 8 Sep 2022, 04:43 am »
op
i would think odyssey would do very well driving atc's which require a lot of power but also a smooth treble and a touch of warmth in the midband, all of which the odyssey amps typically deliver
your choice of linestage (ss or tube) can affect whether the sound is more 'transparent' or 'romantic' and also how the system presents the soundstage
don't worry about biwiring, it is a red herring 99% of the time
good luck
