my dot bryston dot com
0 Members and 1 Guest are viewing this topic. Read 4980 times.
Calypte
« on: 21 May 2022, 10:51 pm »
What am I doing wrong?  I cannot get into my.bryston.com.  It was working earlier today.  My device (BDP-pi) is working.  My network is up and running.  I can access the internet just fine.  The LCD display says "Stopped."
drummermitchell
Re: my dot bryston dot com
« Reply #1 on: 21 May 2022, 11:09 pm »
I could be wrong but......
mybryston.com
Stresss I know all about it
drummermitchell
« Reply #2 on: 21 May 2022, 11:10 pm »
Forget the first.
drummermitchell
« Reply #3 on: 21 May 2022, 11:11 pm »
That’s what I use for the bdp-2
Spyman
« Reply #4 on: 21 May 2022, 11:38 pm »
Drummer is right. There’s no period after “my”.
Calypte
« Reply #5 on: 22 May 2022, 01:58 am »
Then this has been unworking for over four years.
UPDATE: my.bryston.com has worked for years.  Not today.  However, I was able to get into my player with bryston-bdp-pi/local
Thank you, everybody.
abk456
« Reply #6 on: 22 May 2022, 07:07 am »
Definitely a problem
PeterG
« Reply #7 on: 22 May 2022, 01:31 pm »
same issue for me....started yesterday afternoon, mybryston.com won't load on my LAN....BDP-3 and BDA-3.14....plenty of restarts, router, gear etc.....nothing
WRWSTD
« Reply #8 on: 22 May 2022, 02:25 pm »
Yes, I noticed this issue as well. The way around it for me is simple. Just load the web address of the device manually in the address bar of your browser. It can be found on the display when using the up/down arrows on the front panel.
Calypte
« Reply #9 on: 22 May 2022, 02:54 pm »
There are numerous previous discussions in this forum, going back many years, where it's my.bryston.com, and that's always worked for me.  But neither form of that URL works now.  I also discovered that support.bryston.com doesn't work.  I think these issues are related.  In any event, bryston-bdp-pi.local got me into my player.  Or /local -- either works.
PeterG
« Reply #10 on: 22 May 2022, 03:38 pm »
same experience here….tried a couple of downloads from the bryston website…support links don’t function….the local device website works for me as well…thanks for that
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #11 on: 22 May 2022, 04:00 pm »
Hi Folks,
The factory in Peterborough was hit with a bad storm and power is out so no server for my.bryston.com
james
« Last Edit: 22 May 2022, 05:17 pm by James Tanner »
PeterG
« Reply #12 on: 22 May 2022, 05:29 pm »
thanks James
bokko
« Reply #13 on: 23 May 2022, 12:32 am »
Hope all is well there Ottawa is in pretty bad shape
« Reply #14 on: 23 May 2022, 02:48 pm »
Yes Peterborough was hit hard as well - still no power.
james
abk456
« Reply #15 on: 24 May 2022, 09:35 pm »
This is probably a silly question but if we can access our BDA 3 directly by typing in the IP address, what is the purpose/advantage of going through the bryston server for my bryston.com?
Calypte
« Reply #16 on: 24 May 2022, 09:54 pm »
Can you access Manic Moose that way?
OTM
« Reply #17 on: 24 May 2022, 09:57 pm »
That is how I access MM on BDP2/iPad.
Short cut on desktop.
David
Highendfool
  • It is what you think.
« Reply #18 on: 25 May 2022, 01:31 pm »
Good question! Hopefully we’ll get an answer too! 😃
« Reply #19 on: 25 May 2022, 11:51 pm »
Just convenience.
james
