SOLD – Stylus Scale, UV Stylus Cleaner, Weight, Zero dust $92.00
0 Members and 1 Guest are viewing this topic. Read 389 times.
undertow
SOLD
Paypal F/F – GIFT payment only
48 state shipping included USPS Priority.
Price - $92.00
This kit was put together to use with a table, but sat in the closet for about a year.
The price here is less than the Digital Stylus Tracking force gauge.
All items are still new in the box.
You will receive all 4 below for proper turntable setup and care.
1 – Digital Stylus Scale, which is the same as a Pro-Ject Audio - Measure it II - Digital Tracking Force Gauge
WITHOUT the Project name on it.
However, this is not the cheap digital scales sold everywhere it has the more accurate
and better use interface with “Touch screen” keys vs. standard buttons you will see on others similar.
https://www.amazon.com/Pro-Ject-Audio-Measure-Digital-Tracking/dp/B002IZFD2U
2 - Hudson Hi-Fi Turntable UV Stylus Cleaner Vinyl Cleaning – Requires 2 x AAA batteries
Most complete deep cleaner for stylus care.
A UV stylus cleaner is the simplest way to achieve residue-free cleaning in only 15 seconds. Once turned on, the UV cleaner provides LED illumination turn-on that makes it easy to watch the cleaning action. Rest assured that you will be able to thoroughly clean your stylus without damaging its adhesive or sensitive rubber parts.
https://www.amazon.com/gp/product/B08VND63NQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
3 - Viborg LP628S Record Weight Disc Stabilizer, Silver 60Hz Turntable Level, 280G (9.9 OZ) HiFi 3 in 1 Vibration-Proof Vinyl Clamp with Bubble Leveling (60Hz, Silver)
•   Helps eliminate vibration, feedback rumble and sounds better.
•   Liquid inside never leaks out.
•   The puck is solid aluminum alloy, has a good heft to it, and fits the spindle properly.
•   The bubble level is a nice touch and eliminates the need for a spirit level.
•   Improves the speed and timing specially on lightweight platters.
https://www.amazon.com/gp/product/B017EXELKU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
4 - Hudson Hi-Fi Turntable Stylus Cleaner Vinyl Cleaning Gel Bubble
•   HEAR THE DIFFERENCE: The anti zerodust stylus cleaning action will enhance the audio quality of your turntable by improving the noise to sound ratio. For optimal results have the tonearm raised then lower it onto the vinyl record cleaner stylus gel three times.
https://www.amazon.com/gp/product/B07YRYT1QC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
« Last Edit: 16 May 2022, 08:09 pm by undertow »
