0 Members and 1 Guest are viewing this topic. Read 2598 times.
fed by the laptop
I connect my Roon ROCK NUC directly to my Holo May KTE DAC via USB.
This is all new to me, your setup looks clean and simple. I went in another direction. Built a i7 music server, Windows 11 with JRiver app, old Dell monitor for display plus the free Gizmo remote app on a rooted Nook Color for remote access.What is your Roon UI?Does Roon run headless and you use a tablet to make music selections?Are you paying $120/year
General-purpose computers should not be in the playback chain.
I connect my Roon ROCK NUC directly to my Holo May KTE DAC via USB. That is about 10x more costly than the Schiit system. I used to have a Schiit Yggdrasil DAC and I still have an older Bifrost and Valhalla--excellent and reliable for the price.
As long as the Pi will handle the load... My biggest concern was just that even though it is a very capable little system, it's not a powerhouse, and I was worried about things like throughput, latency, etc.
It seems like that might be the best of both worlds (though I'm still wondering what pushed newzooreview to migrate to the NUC at that point... I'm still wondering if that isn't the best way to go, even if it is more expensive... hmmmm).
It will take a bit of trial and error to find out if the Pi will work for you. I moved on from low powered music servers.
The only reason I migrated to the NUC is that I use Roon, and the NUC is the canonical Roon server configuration...If you are not running Roon, then experimenting with a Raspberry Pi connected by ethernet to the same network hosting the NAS should work well.
I'm going to have to mull it over, maybe try a few different software flavors. I may start on the low end just to get something going, then work my way up as I purchase more gear. Hopefully in a period of months, not years though. I'm kinda thinking the NUC/Roon might be what turns out to be the 'stable' platform that I stick with for a while, but I say that before I've even seen what Roon looks like or heard what it sounds like, so it's a little premature. I'll get there. And I'll report back once in a while to let you know where I'm at. In the meantime, first things first, and I've got a lot of CDs to rip. I welcome any further comments while I start dealing with that.
I went down this same path. For a commercial product, the HAL MS6 was the best I ran across....The other reason it sounds so good is the power supply. The new GaN based power supplies are a very significant step up in performance over a traditional switching power supply.
I'm using a NUC, but with Volumio and am very happy with it. I highly recommend the NUC as a hardware platform; it comes in many incarnations, is very versatile, and solid. ...I bought all of them used on Ebay at a very good price without disks or OS, and then populated them myself with a large SSD and Linux.
Have not been unhappy with Pi3+Allo HAT (have run Allo Boss DAC, Allo Digione spdif, and Hifiberry Digi+) over a number of years. Used PiCore and Volumio for s/w.Currently enjoying a Pi4 usb out (Volumio again) to my Wadia DAC/Pre.I get that there are higher end toys in this space, but have personally not been motivated to part with the $ for any.
