0 Members and 1 Guest are viewing this topic. Read 3668 times.
Passive bi-amping is a bad idea, IME. With different amps it's really hard to match their different gain levels. On the other hand, active bi-amping is a wonderful solution to getting the best out of 3 way speakers.
What is your current amplifier?I'm not a fan of passive bi-amping.
I'm currently using a Van Alstine Vision SET 400, 225w/channel solid state. Speakers being considered are B&W 801 Nautilus.
I would live with a single SET 400 and the B&W speakers for a while before deciding on bi-amping.
active bi-amping is always better than a passive setup.
You cannot say that, there are way too many factors to have such a generalization.With a hybrid ESL, different amps that suit each kind of driver element (ESL/Dyanic) makes a lot of sense, since each likely performa sbest with a different amplifier. And here, the significant skewing of an amplifier into a capacitive load will not be kind for delivery of power to the dynamic bass driver.dave
It is recommended that I should bi-amp some speakers I'm looking into getting. They are older, large B&W's and though I believe my current SS amp could drive them well, I've been told that to get their best I might want to look into bi-amping them. The speakers call for 50-1000 watt. Don't really want to get insane with $$, but could spend some. If I'm going to be driving the 15" woofers with their own amp what should I be looking at? 300+ watts/channel?
To avoid disappointment you must be aware more amps, more connections, more output Transistors, more Watts etc are not the hi-fi road, just more expensive and maybe more sound. With bi-amp you will note the sound will be different but not better due many equipments in the system.
My experience in running a single amp full range has been that very frustrating. No single amp was best at everything. For example, finding an amp that provided the needed control of the bass (via high damping factor) and the mid/treble realism that my tube amps provide (no local or global feedback, a single output tube per phase). Yes, the additional amps are an expense. Yes, the additional interconnects and power cords are an expense (I'm using MasterBuilt Ultra interconnects and power cords, so yes more expensive). Was the additional cost and complexity worth it? Is the realism of the result better? Is the opportunity to fine tune the level of the top and bottom amps worthwhile? In my experience, absolutely yes.
