Internal Speaker Wire
0 Members and 1 Guest are viewing this topic. Read 923 times.
AndrewDIY
« on: 7 May 2022, 12:32 am »
Any recommendations for internal speaker wire? I was looking at Amazon Basics 14-gauge 99.9 oxygen-free copper multi-strand (it's only $35 for 100ft). Would this be suitable? I believe Danny uses a solid core internal copper wire but didn't know where to purchase something similar?
Hobbsmeerkat
Re: Internal Speaker Wire
« Reply #1 on: 7 May 2022, 01:46 am »
The wire we use isa custom 16-gauge oxygen-free coated in polyethylene.
Most wire you will find online is coated in PVC which is less than ideal for sound quality.
AndrewDIY
« Reply #2 on: 7 May 2022, 01:51 am »
Thanks, Hobbs. Do you all sell that wire or just for kits?
Hobbsmeerkat
« Reply #3 on: 7 May 2022, 01:52 am »
We do, it's 80 cents per foot. You can shoot us an emails and we'll get you taken care of.
AndrewDIY
« Reply #4 on: 7 May 2022, 01:55 am »
Awesome, thank you!
