BDR Sound ENHANCEMENT EQUIPMENT - Set of 3 Cones and Isolation pads -1/4-20 post
0 Members and 1 Guest are viewing this topic. Read 350 times.
undertow
48 state shipping Included via Priority USPS
Paypal FRIEND/GIFT no fee payment ONLY
PRICE - $90 all 6 pieces
BDR Cones and Isolation pads
ONE set of 3 available - they are the MK4 version - They come with the standard 1/4-20 threaded studs, you can buy adaptors for all size threads.
https://www.musicdirect.com/vibration-control/bdr-cones
https://www.musicdirect.com/vibration-control/bdr-lm-disc-carbon-fiber-isolation-pad-ea
- comes with standard 1/4-20 threaded studs x 3
- comes with 3 cones and 3 isolation pads x 3
Retail for set of 3 cones - $60.00
Retail for set of 3 pads - $90.00
Retail Total = $150.00
Specs. -
Molded from Carbon Fiber and Resin, Extremely Strong and Flexible: BDR Cones Provide Remarkable Isolation, Enhance Resolution, and Come in Two Versions
Molded from a proprietary compound of carbon fiber and resin, and featuring a herculean crush point of 10,000 pounds, BDR cones combine unusual strength and flexibility with internal 1/4"-20 threading to provide excellent isolation from vibration, resonance, and noise. Measuring one-inch tall by 1.618-inch wide, they can be placed under any component or speakers to enhance focus, stability, resolution, and more. Available in two versions (details below, select from the drop-down menu above), they can be mixed and matched to your listening tastes. Plus, they seamlessly pair with BDR disc isolation pads. And yes, these seemingly simple devices really do work – 100% Music Direct Guaranteed.
Placement note: BDR cones perform best when their flat side rests against the component's chassis and the rounded tip points down into the shelf.
Mk3 has a slightly warmer tonal balance, with a little extra oomph on the bottom end, and is designed for solid-state gear.
Mk4 is slightly cooler than its sibling, with greater top octave extension and detail, and less emphasis on the lower frequencies. It sounds great with tube equipment.
Get Improved Sound with the BDR LM Disc Isolation Pad: Designed to be Used as a Set, Each Disc Slips Under Stock Feet of Components, Speakers, and Racks
Measuring just 0.34” tall and 1.5" round, the BRD LM disc isolation pad is surprisingly effective at providing isolation. It improves bass weight and control, extends and smooths treble response, and enhances midrange clarity and presence. Just slip a set under the stock feet of any piece of gear to hear an instant difference. We recommend using them under BDR Cones for an incredible upgrade. LM Discs can also be used under speaker spikes or under any equipment rack. Each LM disc can support more than 400 pounds. Put a set to the test today! Backed by our 100% Music Direct Satisfaction Guarantee.
