Audio Alchemy DLC remote options?
0 Members and 1 Guest are viewing this topic. Read 2323 times.
scott_man
« on: 5 Apr 2005, 05:33 pm »
Dear all:
As many of you know, all controls for the AA DLC preamp are from the remote "wand".  Do any of the universal remotes come pre-programmed with the codes for the DLC?
Thanks.
Scott.
scott_man
Any Help?
« Reply #1 on: 7 Apr 2005, 03:00 am »
Dear all:
Best option:  A universal remote with AA DLC codes.
Another option:  Anyone out there who owns an AA DLC who would be willing to program a learning remote for me?
Thanks.
Scott.
scott_man
« Reply #3 on: 8 Apr 2005, 03:11 am »
Quote from: jswallac
Try this link:  http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=pronto&db=devices&br=audioalchemy&dv=preamplifier&md=digitallinecontroller&fc=&kw=Audio%20Alchemy%20DLC&st=&dt=&so=&pg=1&file=ccf_templates/preamps/aa-dlc.zip
It is from remotecentral.com.  I did not open it, so I am not sure how useful it is.
Thanks... I saw this -- it appears to be binary file for the Philips TS-1000... It is not "rated"  :cry: I'm not sure if it works ... and I don't have a TS-1000 to try it out -- if I knew it worked on the TS-1000 and/or other Philips Pronto remotes, it would be a different story.  :wink:
Anyone out there have the DLC and the Philips to test the functions  :?:
Scott.
doug s.
  • makin' music
Re: Audio Alchemy DLC remote options?
« Reply #4 on: 8 Apr 2005, 07:39 pm »
Quote from: scott_man
Dear all:
Thanks.
Scott.
if anyone has any info on these, it would be dusty vawter from channel islands audio...
doug s.
