Pneupod NP-2 (PNEUMATIC ISOLATION DEVICE) Set of 4
0 Members and 1 Guest are viewing this topic. Read 623 times.
Rivalaudio
« on: 26 Apr 2022, 02:00 pm »
Up for sale are my Pneupod NP-1's which are upgraded to NP-2 specifications (holds up to 160lbs!)
These feet are incredible and the only reason im letting them go is I no longer have my turntable.
Pneupod NP-2
Foot diameter                                                             3 inches (76.2mm)
Foot height (deflated)                                              1.25 inches (31.75mm)
Foot height (properly inflated)                            1.50 inches (38.1mm)
Foot weight        1/2 lb. (.23 kg)
Max weight capacity per foot                                40 lbs. (18 kg)
Max weight capacity per set of three                  120 lbs. (54 kg)
Max weight capacity per set of four                    160 lbs. (72 kg)
Pump Type        Piston
Warranty        5 Years (covers all defects in manufacturing)
Retail for a set of 4 is $1395. I will let these go for $600 $475 and will pay shipping in the US. PayPal, you will need to cover the 3%.
« Last Edit: 11 May 2022, 02:26 pm by Rivalaudio »
Rivalaudio
Re: Pneupod NP-2 (PNEUMATIC ISOLATION DEVICE) Set of 4
« Reply #1 on: 27 Apr 2022, 12:20 pm »
Price reduced to $550.
Rivalaudio
« Reply #2 on: 1 May 2022, 07:47 pm »
Bump
Rivalaudio
« Reply #3 on: 11 May 2022, 02:25 pm »
Price reduced to $475
