0 Members and 1 Guest are viewing this topic. Read 2843 times.
Speakers are ofen damaged by excessive volume with underpowered amps.
I wouldn't be too concerned. Speakers are ofen damaged by excessive volume with underpowered amps. Lots of audiophiles run with amps that exceed the max power ratings of the speakers with no issues. There's an old saying: Speakers do not like to reproduce square waves.
Statements like this are very misleading, no one ever damages a speaker with "under powered" amps (whatever that means)
Can anyone provide more clarification on this? Any assistance appreciated. I realize that quality amplification that is higher in power than a speakers max recommendation can be used, but I'm concerned that the amount of power that I am proposing would be past that point. My other concern is the comment made to me about single driver speaker designs be less well able to handle a lot of power.
Thanks. I was aware of this, and have even done it myself in the past. However, I was warned by an audio industry expert that single driver speaker designs cannot tolerate a lot of power very well, even when not played at anything like excessive volume. Which is what prompted my question here. The integrated amp in question is 200wpc. Granted, I very seldom ever play music loudly in this setup.
The simple answer is that it you listen at the same loudness level no matter what amp you are using, it doesn’t matter if the amp is 15 watts or 500 watts. That said, if you listen too loud with an underpowered amplifier and cause that amp to clip, you can do damage.
Louis will not reveal how much power his drivers will handle, he's absolutely phobic to specifications. So everyone has to dance around this issue. Yes clipping (overloading - producing a square wave) a small amp is more dangerous to the driver (can burn out the voice coil as it tries to duplicate the square wave) than being overloaded with a clean/undistorted signal. My concern in your case is the usable range of the volume control on a 200 wpc amp when used with this loudspeaker. Older style volume controls or pots (as they were called) had a nasty habit of being extremely sensitive at normal listening levels (having a usable range varying between say 9AM and 10AM on the dial) with sensitive loudspeakers. See if you can try it out before purchase.
The simple answer is that it you listen at the same loudness level no matter what amp you are using, it doesn’t matter if the amp is 15 watts or 500 watts. That said, if you listen too loud with an underpowered amplifier and cause that amp to clip, you can do damage.If you are getting this new amp in order to allow yourself to increase your volume to louder than before levels, then you have to be aware that at a certain point, you could potentially damage your speakers and yes, single drivers, generally speaking will not handle as much power as traditional speakers.
