X-On Wall, and X-CS No Rez, and crossover install
0 Members and 1 Guest are viewing this topic. Read 916 times.
HT1278
« on: 19 Apr 2022, 05:50 am »
For the X-On wall, where is the best place to put the crossover?
Wanted to put NoRez in but then I was debating on where the crossover would go.
     Also does anyone have a cut sheet for the No Rez for the X-CS or the X-On wall?
It was very much trial and error for me putting No Rez in the X-LS that I just did.
My flatpacks are from Denton Woodworkers.
Here is an image of inside the X-LS.
Vince in TX
Re: X-On Wall, and X-CS No Rez, and crossover install
« Reply #1 on: 19 Apr 2022, 02:47 pm »
I actually placed my crossovers before I installed the no-res.   I put them center (between the drivers) below the cup.
EDIT:  Side note, I didn't use a cut sheet.   I just measured each space and rough cut it on the fly.
Danny Richie
    • http://www.gr-research.com
« Reply #2 on: 21 Apr 2022, 07:59 pm »
What you did is fine.
