Powervar ABC-1200-11 power conditioner
0 Members and 1 Guest are viewing this topic. Read 991 times.
Cave
« on: 17 Apr 2022, 12:18 am »
Powervar power conditioner.
Shipping would be whatever it is from 97003, no extra money made. Weighs ~45 pounds. Paypal add 3%.
$350.00
(Taken from a previous posting)
Don't be fooled by pretender manufacturers who do things half right. This is NOT an outlet, noise filter(s), high voltage surge clamper (TVSS), or some other combination of less than paramount technology that does not meet Institute of Electrical and Electronics Engineers standard (IEEE C62.41) used by the National Semiconductor Industry.
POWERVAR power conditioners offer a power protection foundation that protects systems from Destruction, Degradation and Disruption. Common mode noise (present between ground and neutral wires) and normal mode noise (present between active and neutral wire) are purged when POWERVAR is used.
The multi-stage POWERVAR incorporates three stages of conditioning using the following components.
1. Low impedance isolation transformer (toroid). Does not limit current!
Isolation transformers help eliminate common mode and normal mode noise or voltage disturbances as permitted by the electrical code (bonding to the ground wire to permit voltage disturbances a clear pathway to the earth and away from your electronics). Both and LOW and high voltage (amplitude) transients are shunted away from your fine electronics to ground.
2. High quality AC noise filter. A filter removes higher frequency, low energy, voltage or noise disturbances.
3. Surge diverter. A diverter takes all high voltage transients and diverts them safely away from your precious electronics.
IMPORTANT NOTE: This unit does not regenerate the sine wave. The unit removes all AC line voltage transients and protects your circuits providing a clean wave form. This unit will not tolerate a square wave INPUT or any other consistently improper wave form INPUT.
« Last Edit: 26 Jun 2022, 09:05 pm by Cave »
Cave
Re: Powervar ABC-1200-11 power conditioner
« Reply #1 on: 26 Jun 2022, 09:06 pm »
bump
Cave
« Reply #2 on: 25 Nov 2022, 05:19 pm »
bump
