SOLD: Focal Aria CC900 piano black center channel, REL T/9i 10" subwoofer, black
0 Members and 1 Guest are viewing this topic. Read 926 times.
taloyd
[selling this for a close friend!]
One of my good friends (while locked in during the heights of the pandemic in late 2020) decided to GO ALL IN on a really, really nice system to keep him company during the lockdown and beyond.
Towards that end he began auditioning numerous speakers and electronics, and purchased a complete 5.0 Focal Aria system with super-nice Aria 926 floorstanding speakers, and a overachieving and attractive REL subwoofer. After a few fruitless months trying to shoehorn the 5.1 system into his apartment, lifestyle, and furniture, he decided to simplify to a pure stereo system. He was able to return the dipole surround speakers in time, but the center channel and subwoofer weren't able to be returned. So we have for sale a Focal Aria CC900 center channel in piano black, that matches the incredible tower speakers that he's keeping, and the REL subwoofer that after a lot of consideration, he decided wasn't completely necessary for those towers. He DID say that it was INCREDIBLE on movies though - made easier by  REL's clever input connections, which allows for an and/or of a stereo high-level input from the speaker outs (another set of wires with the provided cable goes to the subwoofer, so the speakers still get the original signal) - or a low-level RCA input, and ~each have their own volume control~. That's very, very cool. In the past, in a similar situation in my house I resorted to using the L input for one system and the R input for another system, and just tried to have the volume magically work for each (it didn't). So REL's solution is much more elegant, and effective.
Neither the subwoofer nor the center speaker have the original packing materials; and both are in immaculate shape (the REL has some smudges on top, but I think those can be buffed out). The center channel can be easily shipped - I have tons of boxes and packing material, and have sent EXTREMELY heavy and delicate amplifiers (Crown Macro Reference, anyone?) so there's no worry there.
The subwoofer is quite substantial, and so I'd be most comfortable with a sale local to Los Angeles (or the San Francisco Bay Area as we visit there often, and possibly San Diego). If someone absolutely wants the subwoofer shipped, then I'd suggest getting the original packing materials from REL, at the buyer's cost. Then we can both be assured that the subwoofer will make the journey safely.
Price for the piano black Focal Aria CC900 is $719.
Price for the REL T/9i subwoofer with the factory cable is $817
The Focal can be shipped at the buyer's cost (actual shipping; packing materials/handling will be taken care of).
The REL is best for local pickup. (Contact me for SF Bay Area pickup, San Diego pickup, or shipping.)
I have lots of feedback on eBay, Audiogon, everywhere under the avatar taloyd. Photos are factory photos! Will load actual photos soon.
Best,
Tal
REL T/9i, black
bought for: $1,299
product page
https://rel.net/shop/serie-ti/t9i/
owner's manual
https://rel.net/wp-content/uploads/2016/09/REL_Serie_Ti_Manual.pdf
specifications:
Type: Passive Radiator, front-firing actve woofer, down-firing passive radiator
Active Drive Unit: 10in., 254 mm long-throw, inverted dust cap, steel chassis
Passive Radiator: 10in., 254 mm
Lower Frequency Response: 28 Hz at -6 dB in room
Input Connectors: Hi Level Neutrik Speakon, Lo Level single phono, LFE phono
Input Impedance: High Level: 150kΩ, Low Level: 10kΩ, .1/LFE: 10kΩ
Gain Control Range: 80 dB
Power Output: 300 watts (RMS)
Phase Switch: Yes, 0 or 180 degrees
Amplifier Type: Class AB
Wireless Capability: Yes - REL Arrow™ wireless system [required], Sold separately
Protection System
Fully Electronic SET-SAFE: Yes
D.C. Fault: Yes
Output Short: Yes
Mains Input Voltage: 220-240 volts, 110-120 volts for certain markets
Fuses: 3.15 Amp semi delay 230 volts operation
6.3 Amp semi delay 115 volts operation
Dimensions (WHD): Including Feet and Rear Panel Controls
13 x 15.2 x 16 in., (330 x 387 x 407 mm)
Add 1.75 in (44.5 mm) in depth when using Hi Level connector
Net Weight: 41.3 lbs. (18.7 kg)
Finish: Gloss Piano Black or White Lacquer
Supplied Accessories
Mains Lead: Yes
Neutrik Speakon Interconnect: Yes (10 Meters)
Focal Aria CC900 (piano black, they call it black high gloss)
bought for: $990
these are currently being sold at Crutchfield (super friendly and knowledgeable dealer!) for $1,099
https://www.crutchfield.com/S-STn4SkrGosU/p_091A900CBP/Focal-Aria-CC-900-High-Gloss-Black.html
product page
https://www.focal.com/us/high-fidelity-speakers/aria-900/aria-cc-900
owner's manual
https://www.focal.com/sites/www.focal.fr/files/shared/catalog/document/notice_aria900.pdf
data sheet:
https://www.focal.com/sites/www.focal.fr/files/shared/catalog/document/aria_cc_900_specification_sheet_gb.pdf
specifications:
Type Two-way bass-reflex center loudspeaker
Speaker drivers Two 61/2" (16.5cm) Flax bass - midrange
1" (25mm) Al/Mg TNF inverted dome tweeter
Frequency response (+/- 3dB) 57Hz - 28kHz
Low frequency point - 6 dB 50Hz
Sensitivity (2.83V / 1m) 91dB
Nominal impedance 8Ω
Minimum impedance 4.3Ω
Recommended amplifier power 40 - 200W
Crossover frequency 2800Hz
Dimensions (H x W x D) 7 7/8 x 21 x 9 5/8" (200x533x245mm)
Weight 23lbs (10.5kg)
« Last Edit: 18 Jan 2023, 07:05 pm by taloyd »
taloyd
Prices dropped. Happy May everyone!
taloyd
REL subwoofer sold locally; Focal center speaker still available.
taloyd
FS: Focal Aria CC900 piano black center channel
« Reply #3 on: 2 Nov 2022, 05:54 pm »
This really needs a new home - and it's sooooo nice. Dropping the price to a ridiculous $517 which is half of what it cost new, and it's a 9.5/10 condition. Was used for maybe a month.
Buy it! Upgrade your most important home theater channel!
taloyd
Focal sold locally; thanks all!
