Verastarr SSA-644 - How to convert to Euro voltages?
0 Members and 1 Guest are viewing this topic. Read 963 times.
Corradobrit
I just moved to Germany and want to configure my two Verastarr amps for 220-230v. I have an SSA-644 (same internally as the SSA-64) and a Studio 6.4, with a handwritten schematic for the 64 but its not very clear and some annotations are obscured.
https://imgur.com/hBaeN2x
There are two unused wires on the toroidal transformer that I assume get connected to the junction box with the black circular ICL component.
https://imgur.com/k48g5v1
All spade pins are used for 220v vs 110v operation. Can anyone provide an image of their 220v wiring? This is how my SSA-644 is setup for 110v.
https://imgur.com/G8j3lHJ
« Last Edit: 13 Apr 2022, 01:47 pm by Corradobrit »
Re: Verastarr SSA-644 - How to convert to 240v?
« Reply #1 on: 12 Apr 2022, 06:52 am »
I just moved to Germany and want to configure my two Verastarr amps for 240v. I have an SSA-644 (same internally as the SSA-64) and a Studio 6.4, with a handwritten schematic for the 64 but its not very clear and some annotations are obscured.
All spade pins are used for 240v vs 110v operation. Can anyone provide an image of their 240v wiring? This is how my SSA-644 is setup for 110v.
This schematic are to 220V, not 240V.
Two 110V windings are suited to 220V mains wall, not 240V.
Wiki inform Germany tension as 230V/50Hz.
« Last Edit: 12 Apr 2022, 08:05 pm by FullRangeMan »
Corradobrit
« Reply #2 on: 13 Apr 2022, 01:46 pm »
Yes correct. The amp will be OK with 220-230V. I've edited the OP accordingly.
