Cold Solder Joint?
0 Members and 1 Guest are viewing this topic. Read 641 times.
WLP3
Cold Solder Joint?
« on: 7 Apr 2022, 06:34 pm »
I built some of Danny's 16 conductor speaker cables, and I am concerned about possibly have cold solder joints due to using a cheap soldering iron.  In soldering the bananas I applied some solder to the inside of the banana and then inserted the tinned wire in the banana.  In some cases, as the connection heated up I was able to slip the wire further down into the banana.  In a couple of cases the banana would not slip down all of the way.  They all seem to be firmly attached.
I guess my questions are:
-Would there be an audible difference caused by a cold joint?
-Could any difference in resistance, etc. possibly hurt my speakers?
-Is there an easy way to test to determine if there are any cold joints?
-Are they fixable by re-heating with a hotter iron?
In general, how long of a break-in period is there on theses cables in your experience?
Bill P
