Black Ice F11 tube integrated amp, San Francisco Bay Area local sale preferred
0 Members and 1 Guest are viewing this topic. Read 488 times.
Meicheng
I'd like to sell this locally in the San Francisco Bay Area. Cash at pickup. Asking $1000.  As new, original owner, infrequently used in an office/second system, silver Fusion 11 tube integrated amp by Black Ice. Mint condition, works perfectly, not a scratch or mark on it. Easy bias with built-in meter. Has several inputs and even a subwoofer RCA output. Manual and original box. Although fairly low powered at 19watts/channel, this amp can drive almost any bookshelf speaker. Wonderful tube sound, no buzz or hum. I like to try a lot of different equipment and its not unusual for me to sell a minty piece a year or two after purchase, to try something else. Maximum Power Output: 23 W per channel at 8 ohms, 1KHz with EL84 Tubes Rated Output Power: 19 W per channel at 8 ohms, 25Hz to 60KHz with EL84 Tubes Frequency Response: (at 1 watt into 8 ohms) 8Hz to 130KHz + 1dB Bandwidth: 15Hz to 80KHz + 3dB; 0dB 19W 1KHz Distortion THD: Less than 1% at 20 V output, 28Hz to 15KHz Circuit Type: Fully Balanced differential push pull Input Impedance: 100Kohms Input Sensitivity: 1V at 1KHz for 0 watt output Output Impedance: 4 ohms and 8 ohms speaker taps Negative Feedback: Less than 4.5 dB Noise and Hum: 95dB below rated output Tube Complement: 4 pcs. EL84 power output; 4 pcs. 12AX7A/ECC83 Power Requirements: 110V-120 VAC 60Hz 6 watts-standby, 350 watts maximum (220 VAC 50Hz option) Dimensions: 14.5 inches wide by 11.5 inches deep by 7.5 inches high Weight: 32 pounds net, approximately 43 pounds packaged.  Please email me directly at [email protected] for pics or with any questions.
