What cables do you guys run off your TT?
0 Members and 1 Guest are viewing this topic. Read 1904 times.
beat
« on: 25 Mar 2003, 08:15 pm »
Hello all,
I was looking at the kimber pbjs (heard they were good) or maybe audioquest diamondbacks. I will probably end up DIY but it seems there are many different approaches in design.
thanks, beat
jcoat007
« Reply #1 on: 25 Mar 2003, 09:26 pm »
Zu Xaus is what I am currently using.
I used to use HGA Silver Lace with good results also.
JoshK
« Reply #2 on: 25 Mar 2003, 09:44 pm »
Do you guys use DIN connectors or run from leads to phono?  I have heard the later is better and when I finally get my Incognito Rega RB300 I will start to find out.
mamsterla
Phono leads
« Reply #3 on: 26 Mar 2003, 11:56 pm »
When I rewired my tonearm - SME 3009/IIi.  I decided to use one unbroken disovery wire from leads (used gold plated RS-232 female pins) to the RCA connectors (cardas GRCAs I think) in a short (< 1m) run.  I did not even shield the cable - I get zero hum and it sounds great.
TheChairGuy
« Reply #4 on: 27 Mar 2003, 03:34 am »
Alpha Core Goertz TQ2's for me off the RCA terminated Thorens TD-316.
