FS Moon 100D Dac
0 Members and 1 Guest are viewing this topic. Read 565 times.
peckjed
FS Moon 100D Dac
« on: 27 Mar 2022, 02:25 am »
Very nice Moon 100D DAC. Excellent sounding DAC - the only reason it is up for sale is I moved to a streamer out of convenience. Below is the information from the Moon website. Please reference photos for conditions and ask any questions! Local pickup in CT is available. $325
The MOON 100D Digital-to-Analog Converter accepts USB, S/PDIF and TosLink inputs. Intended for use with a computer via the USB input, the remaining inputs allow for interfacing with other source components such as a music server, digital transport, etc. All digital input signals are processed through an asynchronous sample rate converter and then 24-bit DACs.The 100D is housed in a compact chassis constructed of rigid aluminium and features a 1/4" brushed and anodized faceplate. Don't be deceived by its small footprint since trickle-down technology dominates, thanks in no small part to its larger sibling, the 300D ... Amazing things do come in small packages.
Using 24-bit/1.411MHz processing, the MOON 100D will faithfully reproduce your digital music in an effortless fashion. Accepting an input signal from 44.1 to 192kHz with a bit-depth range from 16 to 24-bits, jitter is a virtual non-issue thanks to the asynchronous operation of this DAC. Sonically, it portrays all of the Simaudio hallmarks: clean, powerful, fast, extended bass combined with an open midrange and airy extended high frequencies.
An important note about the 100D's USB input:
The USB input on the MOON 100D accepts a digital audio signal of up to 16-bits/48kHz.
Technical aspects:
Power supply with 3 stages of DC voltage regulation
A fully asynchronous sample rate converter
BurrBrown PCM1793 high-resolution 24-bit/192-kHz D/A and 8X oversampling digital filter
Accurate digital clocking system for exceptionally low intrinsic jitter levels
Advanced analog signal path using a DC servo circuit and proprietary analog filter
Accurate matching of military-grade components with ultra-tight tolerances using surface-mount technology for extremely short signal paths
Compact, rigid all-aluminum chassis with gold-plated RCA connectors
ceylon
Re: FS Moon 100D Dac
« Reply #1 on: 4 Apr 2022, 01:58 pm »
looks good. messaged you.
