Monarchy DIP or SF Ultra jitterbug in chain w/ newer DACS??
0 Members and 1 Guest are viewing this topic. Read 1869 times.
byteme
Does it make sense (i.e. provide sonic benefit) to toss something in the chain to reduce jitter before a current DAC?  Specifically I'm running a McCormack SST-1 transport and Channel Islands VDA-1 or Scott Nixon tubedac.
Anton
« Reply #1 on: 11 Apr 2003, 09:45 pm »
I use two SF Ultrajitterbugs in series before my DAC (MSB Gold Link DAC III with P1000 power base) and they make a difference.
JoshK
« Reply #2 on: 11 Apr 2003, 09:52 pm »
Forget jitterbugs and what-not and upgrade the clock to a superclock or other in the transport itself.
eico1
« Reply #3 on: 11 Apr 2003, 10:16 pm »
maybe because it's at the dac that counts(pun, sorta). A good clock at the transport will not help if the jitter is caused from lousy transmitter and receiver circuit performance. At least if your using a dac with internal sample rate converter I wouldn't bother, just more chance to further muck thinks up. Not that that may not be preferable to some.
steve
byteme
« Reply #4 on: 12 Apr 2003, 05:11 am »
I ended up talking to Scott Nixon on this and he said he'd familiar with the SST-1 transport and that if I already HAD something like the jitterbut or simlar that it wouldn't hurt to put it in the chain, but if I didn't that adding it or going out to get it wouldn't help.  Apparently the SST-1 has a pretty excellent coax out engineered into it so it doesn't need much help.  This fits with what I heard from Steve McCormack, however, since he actually built the thing I took it with a grain of salt until corroborated by Scott.
Thanks for the help!
