Using the BHA-1 as a Preamp
0 Members and 1 Guest are viewing this topic. Read 653 times.
Highendfool
  • It is what you think.
« on: 23 Mar 2022, 12:39 pm »
I’m looking to add the BHA-1 to my system so I have a good headphone amp and won’t need a preamp.
I’m currently using the BDA-3.14 as my preamp and it’s all I need.
My question is, does the BHA-1 mute the rear outputs when a headphone is connected?
If not, that means turning off the amp every time I listen to phones! (PTA)
Thanks in advance, for any input.
rob80b
Re: Using the BHA-1 as a Preamp
« Reply #1 on: 23 Mar 2022, 07:53 pm »
Correct, no muting of the outputs when using headphones.....still makes for a very good pre-amp IMHO though.
Highendfool
« Reply #2 on: 23 Mar 2022, 08:35 pm »
Thank you for confirming ✌🏻
