Industry Circles
Audio by Van Alstine
jimava
headphone circuit - SET 120 Control vs Transcendence RB preamp
0 Members and 1 Guest are viewing this topic. Read 2477 times.
jandrews
22 Mar 2022, 03:28 pm »
Hello
I'm planning on purchasing a 120 SET amp and am not sure if I'll go the 1-box control-amp route or get the tube RB preamp to accompany a plain 120 power amp.
The control amp has a headphone output and I'm curious if anyone knows how it compares to the RB preamp headphone out.
I'm slightly leaning towards getting the power amp and preamp combo at this point.
thank you
JS
Last Edit: 22 Mar 2022, 04:45 pm by jandrews
Mary
Industry Participant
AVA Associate
Re: headphone circuit - SET 120 Control vs Transcendence RB preamp
23 Mar 2022, 03:00 pm »
Hello jandrews,
The SET120 control amplifier has the exact headphone circuit as the RB preamplifiers.
Mary
jandrews
Reply #2 on:
23 Mar 2022, 05:33 pm »
Great, thank you
Reply #3 on:
23 Mar 2022, 07:06 pm »
Hi Mary, hope to catch with this question, I just bought a T7 preamp from you, can you tell me the phono capacitance, I’m shopping for a new cartridge😊
Mary
AVA Associate
Reply #4 on:
24 Mar 2022, 05:31 pm »
The T7 preamp has our standard MM phono stage with industry standard input impedence of 47K ohm.
avahifi
Industry Contributor
Reply #5 on:
24 Mar 2022, 11:47 pm »
Actually the Control Amp drives headphone directly from the main power amp channels through some voltage dropping resistors. All our preamps drive headphones after unity gain ultra low distortion current buffers that isolate the gain stages from the low impedance headphone loads. In both cases you are hearing your headohones as directly to the music as possible.
jandrews
Reply #6 on:
30 Mar 2022, 03:42 pm »
Just placed an order for a Transcendence 10 RB pre and a SET 120 power amp from AVA.
Sounds like the wait is 3 or 4 weeks. Really looking forward to using these amps with my Omega Super 7's (95db, original version). Also have some LRS's on order since January and recent posts suggest that is a great pairing too. I am forgoing the phono stage in the pre which I'll probably regret later but that's OK , I have a decent phono pre already.
Industry Circles
jimava
