Paradigm Seismic 10 Powered Subwoofer (compact 10") PRICE BREAK!!!
0 Members and 1 Guest are viewing this topic. Read 1731 times.
Bostown
  • BASS CLUB [Boston Audio Stereo & Social Club]
    • Second Time Sound - Audio Gear Re-Purposed
performs great for 2 Channel Audio and/or Home theater system use.
was $625.00  NOW $550
will consider partial trades : (McCormack Micro Power Drive amp, Musical Fidelity X-AS100 Stereo amp, Musical Fidelity Nu Vista Preamp - canister style)
Ideally a local sale/pick up in Massachusetts (near Boston) is preferred but we can discuss the possibility of shipping ( buyer picks up the cost involved to make that happen).
Specs:
Single high-excursion driver, dual passive radiators, built-in Ultra-Class-D™ amplifier
Amplifier: High-Current, Discrete Output 1200 watts RMS (20–150Hz @ < 0.1% THD), 4500 watts Peak
Amplifier Features Auto-On / Off, Trigger-On / Off, soft clipping, thermal protection, electrical shorting protection
Bass Driver 254-mm (10 in) RCR™ mineral-filled co-polymer polypropylene cone, oversize surround, 76-mm (3 in) bifilar 8-layer voice-coil, high-temperature Apical™ former, dual spiders. AVS™ die-cast heatsink chassis, 8.5-kg (19lb) magnet structure
Passive Radiator Dual 229-mm (9 in) balanced-plane, high-velocity passive radiators
Low Frequency Extension 21 Hz (DIN) *
Subwoofer Cut-Off Frequency Variable 35 Hz – 150 Hz
Subwoofer Contour Variable 0 to +6 dB at 60 Hz
Sub./Sat. Phase Alignment Variable 0º– 180º
Line Level Input RCA (S/E) or Balanced-XLR. From Sub-Out / LFE-Out of receiver / processor or other line-level source
Line-Level Input Sensitivity 100 mV mono
Line-Level Input Impedance RCA: 25k ohms; XLR: 20k ohms
Internal Volume 19.7 L / 0.69 cu ft
Height, Width, Depth: 13-1/4 x 12-3/8 x 12-3/8 in
Weight 49 lb
Finish: Black Ash
Anyone interested in an Nvidia RTX 3080  Founder's Edition Graphics Card -  There's one in my sell pile as well. ( in Box, used for about a week)
« Last Edit: 20 Mar 2022, 02:39 pm by Bostown »
