0 Members and 1 Guest are viewing this topic. Read 4069 times.
I'm having a set of speakers built, and the builder doesn't really beleive that XO caps make that much of a difference.My questions are, in your opinion, do different caps sound different?What in your opinion are the best sounding XO caps.Speaker design is a 3-way 10" woofer. 5 inch mid, ribbon tweet.Thanks
No expert opinoin by a suggestion - Have your crossovers housed in boxes external to the speakers. Wooden cigar boxes are nice for that task. Then, if you decide you wants to play slap and tickle with your crossover (or go line level crossovers and multimaping) its made quite a bit easier.You might also consider compromising your old school speaker builder and involving him in the selection of caps, i.e. send him a couple pair of Vishay MKP1837.01uf (Mouser <$2ea) and suggest he try them for bypassing series caps and ask his opinion.....
...One problem with a lot of the "magic" caps is that they're huge. That adds inductance, and can also make them more prone to being microphonic. ...
How would the inductance of these large magic caps be a problem when used in a x-over? Over what frequency range would this added inductance be problematic? How much inductance are you talking about? Could you work out an actual example with ballpark numbers?Thats quite interesting that these large caps are more microphonic. I'm quite familiar with microphony with many ceramic caps, but this is a new one, and I'd like to learn more. Could you provide a reference, a URL?TIA,Occam
