What about Switch Boxes?
0 Members and 1 Guest are viewing this topic. Read 1174 times.
S Clark
« on: 10 Mar 2022, 11:50 pm »
Thinking about using a Luxman AS 4ii switchbox to connect two tonearms to one phono pre.  I'd need one less preamp and one less interconnect.
Noise??
toocool4
Re: What about Switch Boxes?
« Reply #1 on: 11 Mar 2022, 10:31 am »
Why not just find a phonostage that accommodates 2 connections?
Wayner
« Reply #2 on: 11 Mar 2022, 01:17 pm »
Noise??
Turn your volume down to zero when switching or you may have a loud pop, perhaps even a tweeter killer pop. Make sure the switcher never switches the ground wire or the shields of the interconnects, just the center unbalanced conductor.
Wayner
S Clark
« Reply #3 on: 11 Mar 2022, 10:04 pm »
I think I'll just keep the set up as it is-- 4 tonearms in two systems with 4 phonostages.  In one case, I'd be adding noise to a LOMC before going into the phono stage. I was hoping to move a mono rig into my Hagerman Trumpet.  I'll just keep the little Vista in place.
