Industry Circles
GR Research
Danny Richie
Dipole sub - 2 or 3 drivers?
0 Members and 1 Guest are viewing this topic. Read 786 times.
Martin-Andersen
7 Mar 2022, 01:15 pm »
Hi, I am seeking advice on a sub for my Magnepan 3.7i
Should I buy the dipole sub with 2 or 3 drivers?
jparkhur
Re: Dipole sub - 2 or 3 drivers?
7 Mar 2022, 01:20 pm »
If you can do 3, great. They would be similar to 3/4 height of 3.7s. Two would be more than acceptable, but three is more better!. It is like the LRS bs the 3.7.. bigger. If the room is big enough for 3.7 then get three..
Danny Richie
Facilitator
Reply #2 on:
10 Mar 2022, 12:51 am »
It can really depend on your room size and how loud they need to play to keep up with the level of the Maggies.
It is also likely a pair of duals will be plenty.
Industry Circles
GR Research
Danny Richie
