Industry Circles
Bryston Limited
BDP-pi and USB
BDP-pi and USB
0 Members and 1 Guest are viewing this topic. Read 770 times.
Calypte
BDP-pi and USB
5 Mar 2022, 11:21 pm »
I finally got the BDP-pi to work with my non-Bryston DAC via USB. But now the LCD display doesn't work. Should I expect this?
unincognito
Industry Participant
Re: BDP-pi and USB
15 Mar 2022, 01:44 pm »
Correct, the data bus for the display interferes with the USB bus so the display turns itself off.
Chris
Calypte
Re: BDP-pi and USB
Reply #2 on:
16 Mar 2022, 08:10 pm »
Thank you. It turned out that I had to return to a coax connection. Using USB, the gear sounded great with CD resolution (44/16). When I tried hi-res files (192/24), I got a lot of crackling. It was unlistenable. The DAC is Emotiva, not Bryston.
Industry Circles
Bryston Limited
BDP-pi and USB
