What is Gain of Odyssey Khartago?
0 Members and 1 Guest are viewing this topic. Read 2210 times.
GeorgeAb
« on: 5 Mar 2022, 08:03 pm »
What is the gain of the Odyssey Khartago (standard version)?  Gain spec is not provided on Odyssey site.
I ask as I use an active crossover and tri-amp directly to drivers. Therefore, I need to somewhat match gains of amps. My main amp is Simaudio Moon Evolution W-7 at 31dB gain. The bass section uses a Balanced Audio Technology VK-220 rated at 23dB gain. The Khartago is used as a spare, but have used in the bass section previously. I believe it is 23 to 26dB gain, but would like to know. Have active crossover at -5dB for bass section compared to mids which works well for providing perceived flat response at listening position per REW. I get similar SPL for VK-220 as the Khartago so I believe it is 23dB, although 26dB would be more common.
klaus@odyssey
Re: What is Gain of Odyssey Khartago?
« Reply #1 on: 5 Mar 2022, 08:05 pm »
Of course that individually depends on each amp ,  but look at around 30 dB..give or take +- 2 dB
