Reuse Tube Connectors?
0 Members and 1 Guest are viewing this topic. Read 721 times.
tortoiseman2542
« on: 21 Feb 2022, 02:14 am »
Is it possible to reuse tube connectors?  I am going to move the max X-LS Encore crossovers I have from my Moho over to my piano gloss rosewood X-LS’s.  Do I have to buy new tube connectors?
Robert
Hobbsmeerkat
Re: Reuse Tube Connectors?
« Reply #1 on: 21 Feb 2022, 02:20 am »
You can reuse them, but youll need to keep a length original wires attached to use as leads for connecting to the new crossover.
That said, it would be easier to just start with a fresh set.
