Bryston 4B3 questio
0 Members and 1 Guest are viewing this topic. Read 978 times.
canuck5
Bryston 4B3 questio
« on: 20 Feb 2022, 04:28 am »
Stumbled upon a situation, when I dial down the volume with my preamp ( without any music playing,),  I can hear noise in left channel, same as  increasing the volume (something like a clicking noise ).  Right channel no noise is heard at all.  When playing music, no noise is heard.
Would this be indicating an issue with my amp or preamp?
Like I mentioned, I stumbled upon this when I thought my preamp was muted when dialing down the volume.
Hope I explained the situation well enough.
I running an Allnic preamp
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
Re: Bryston 4B3 questio
« Reply #1 on: 20 Feb 2022, 10:52 am »
Did you disconnect the pre amp and listened if any unwanted sounds were still there?
 :roll:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 20 Feb 2022, 01:54 pm »
It sounds like a dirty volume control on the preamplifier
If you change the left channel cable with right from the preamp to the amp and the noise changes sides - its the preamp
james
canuck5
« Reply #3 on: 20 Feb 2022, 05:04 pm »
Thanks Mr. Tanner. swap out left and right on the back of the preamp, noise appeared in the right channel.
Should of thought of that.
