CMT router bits on sale, 70% off
0 Members and 1 Guest are viewing this topic. Read 647 times.
E-Zee
    • Diy speaker resources and crossover assembly services
« on: 19 Feb 2022, 05:41 pm »
Slightly off-topic, but this is also a DIY related circle so I wanted to share that mikestools.com has several items at significant discount, specifically 70% off of CMT router bits.
https://www.mikestools.com/SaleOffers.aspx
CMT are great bits and will outlast and outperform any of the budget China bits sold on Amazon and eBay. There are some other decent deals also available (sandpaper, kreg pocket screws).
Inventory is disappearing fast and many of the items are only 1 or 2 left, so if you want it and you see it, don't wait.
Regarding shipping costs, I think they were very reasonable.
As a comparative shipping cost, I bought 29 router bits, 6 packs of 10 full sheets sandpaper, 5 small boxes of kreg pocket screws, one 8" circular saw blade, 2 bottles of blade/bit cleaner, and UPS shipping was $34.
Good luck and hopefully someone gets a good deal on some great bits.  In addition to roundover bits which are almost gone, there are still several pattern and flush trim bits, as well as spiral cut bits, straight bits, and quite a few good dovetail bits for anyone using incra or other similar jigs.  Anyone looking for larger cabinet door profile, raised panel, and other similar bits should still have quite a few options available, and the savings on those larger bits is significant since they start out so high $.
