Military Tube Tester TV 3/BU, great shape / tube appendix & military manual SOLD
0 Members and 1 Guest are viewing this topic. Read 439 times.
joessportster
  • Set & Single Driver Bliss
SOLD  Tester works and includes a military manual and a tube appendix  400.00 "FIRM" plus shipping and fees see pics  I paid substantially more for this tester plus the manual.
The tester with the manuals weighs in at 24 pounds plus packing so shipping wont be dirt cheap, an example to Mass. it would be 53.00
I am located at 28351 North Carolina, Local pickup is available
No it has not been calibrated, But it seems to work fine, I am not sure this model requires much Calibration. When you go to test a tube the first step is to calibrate the meter. You adjust a dial till the meter reads "X" then you go on to testing. I have used it a couple times. Thought I might get into selling tested tubes but its more problem than I want to get into. (Problem meaning dealing with some of the people)
The tester accommodates most of the popular tubes Example, KT88, KT66, 6DJ8, 12A_7, 6sn7 etc.....The appendix is fairly large with a LOT of tubes listed  SOLD
« Last Edit: 16 Feb 2022, 11:51 pm by joessportster »
Delta77
Interested ..!
I'm kinda new to tubes, and have had a couple of problems with Rectifiers (274B) .
Will this unit test rectifiers too.?
joessportster
According to the appendix it will test Rectifiers, I found both 274B and 5u4 in the book at a quick glance.  Shipping to CA will be expensive
Joe
joessportster
Tester has SOLD
