Tidal procedure !
0 Members and 1 Guest are viewing this topic. Read 665 times.
dumanski
Tidal procedure !
« on: 14 Feb 2022, 06:12 pm »
Just subscribed to Tidal Hi Fi plus..
To utilize our trust BDP-1
Does Bryston have a procedure to help get tidal working on Mpad the display has a repeating message with no real diagnosis codes…tried calling Bryston head quarters few times but…I’m sure we are all busy.
Have any of you found a way to make it work.
Cheers !
  • The Demo is Everything!
    • http://www.bryston.com
Re: Tidal procedure !
« Reply #1 on: 14 Feb 2022, 06:18 pm »
The RED usually means you have not signed up correctly - did you sign to Tidal on the Ipad?
james
dumanski
« Reply #2 on: 14 Feb 2022, 06:43 pm »
Correct, I noticed it will do on I pad and tested on I phone same message . However if I re-boot player sometimes prompts to sign in and it will work for a while.
« Reply #3 on: 14 Feb 2022, 07:58 pm »
It may be the BDP-1 is having difficulty due to processing power requirements.
james
