0 Members and 1 Guest are viewing this topic. Read 5331 times.
I've been looking into buying a TEAC AL700P, but college has me at a budget and i've been having a hard time finding an affordable preamp. The TEAC has volume pots on the back, but from what i've heard they're not the best to use, so i've been looking for an affordable and reasonable way to control the volume.I have a component switcher lying around the house, so to my knowledge all I really need my preamp to do is adjust the volume.This popped up after browsing around these forums: (scroll down to ...
My first reaction when I took a look at that mode - what's inside? Certainly not Alps. For less than a $100, I doubt you'll get something decent. If separate channel control is important to you, take a look athttp://tweakaudio.com/EVS-2/Ultimate_Attenuators.htmlThey don't look that fancy, they are more expensive ($350), but they have excellent track records. No, I don't own one, but I'm in the same position - looking for some kind of passive preamp, and this is one of the options I consider.
That just feels odd spending 100$ on an amplifier and 350$ on a pair of volume controllers.Is there no low cost alternative to volume control?
Cripes! I just looked at their site. That's one of the most moronic things I've ever seen. You're putting a bunch of weight on the input jacks, so you can tear them out. And there's absolutely no shielding.Furthermore, there's a really good chance that one of these things will fall right out of the input jack since it's so heavy and clunky. That could send a transient heading right for your expensive speakers.
Thanks for all the advice guys.I've been sufficiently confused to now believe that if I buy a budget preamp I will blow up in a catastrophic explosion, so i'll be buying the next sonic impact t-amp that comes by. Spending 400$+ to power a pair of paradigm titans is a little far out for me, especially when I want to upgrade my source. I think i'll wait until summer when i've got a full time job and maybe then i'll be back here.
Excuse my thread jacking, but how do most integrateds work? An amp with a passive volome control, so a passive pre and an amp would be the same, only in two boxes. Or do they have an active pre section with an amp section.Ryan
Quote from: rynoExcuse my thread jacking, but how do most integrateds work? quote]There are alot of different designs, but T will try to keep it as simple as possible.Integrated amps are very sensitive, sometimes down to .5 volts for max output. But even at 2 volts sensitivity, it May be that sensitive because an extra stage is included for more sensitivity. The theory being that one can rid of the preamp power supply, extra chassis, ICs etc, thus less expensive and at the same time better sounding. So, in essence, the preamp active stage is incorporated into the amp. What is left is basically a volume control of some sort, usually external.Unfortunately, theory and practicality are two different things, if we are talking about ultimate designs and ultimate sound quality. And let's face it, the budget is the controlling factor for almost all of us. Integrates make alot of sense, a terrific bang for the buck.Now, the important question is how well the 1st stage of the amp is designed. Is it as good, or better than an outboard stage with an extra IC.That is why comparing actives to passives is like comparing apples to oranges. The passive isn't checked with the following gain stage. When both are compared to an active, the active may win out.Another question is how good is the CD players analog stage, usually an OP amp. I'd rather bypass that stage more than any other stage, basically use an active preamplifier to replace the op amp. But that is a chore, and no manufacturer will run separate outputs, bypassing the op amp for the average consumer. So the sound quality suffers.Anyway, my .02 worth.
Umm, Rick Schultz does not do too many things that would qualify as "moronic" in general. I don't think he'll appreciate that comment, at all, because you have obviously never used EVS ultimate nude attenuators. I have used a pair for a very long time, connecting/unconnecting literally hundreds of times to dozens of equipment and cables. Not once did it come loose, "send transients," or add RFI noise, or break any jacks. I am actually quite amazed how Rick was able to make it so grippy and sturdy. ...
