Notch Filter
0 Members and 1 Guest are viewing this topic. Read 1646 times.
Richard U
Notch Filter
« on: 1 Apr 2005, 05:01 pm »
I need some help with a notch filter for a pair of RTS-3 speakers.Stupid me, I bought them years ago based on a review and a great price. Dennis Murphy ( murphyblaster.com ) tested these speakers and they have a big rise in the mid bass. When I saw the review, I pulled them out of storage, connected them and sure enough , boom, boom.
I know very little about crossovers. What do I need to fix this and can it be easily attached? Thanks.
Richard
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Re: Notch Filter
« Reply #1 on: 1 Apr 2005, 06:30 pm »
Quote from: Richard U
Richard
It really depends on whether the problem is related to the crossover or box tuning (or possibly both). If it's a lack of baffle step compensation then it should be easily fixed with a crossover modification.
Richard U
Notch Filter
« Reply #2 on: 1 Apr 2005, 06:44 pm »
Rick,
There is nothing I can do about the box tuning but what can I do with the crossover? There is a graph on Dennis's website. Thanks.
Richard
Rick Craig
  • Selah Audio
Notch Filter
« Reply #3 on: 1 Apr 2005, 09:52 pm »
Rick,
Richard
Looking at the measurement it's a box tuning problem. Is it a ported box? I also found a review noting that no bracing was used in the cabinet and the walls are only 5/8" thick. This would make things worse.
Probably the best thing to do is build new cabinets with the correct tuning and good contruction. With a speaker in this price range I don't think it would be worth the time and money to do that.
avhed
Notch Filter
« Reply #4 on: 21 Nov 2005, 06:07 am »
I wonder if the SD RTS-3 speaker is boomy, because only a minority of people say it is. Can it posibbly be your room. I have had the speakers for 5 years, in 2 different homes and they never been boomy.
JohnR
Notch Filter
« Reply #5 on: 21 Nov 2005, 10:41 am »
Hi, you might like to try stuffing the port and see if that improves things - ?
