FS: Peachtree Nova 125se - Integrated Amp / DAC / Headphone Amp
0 Members and 1 Guest are viewing this topic. Read 419 times.
Bostown
  • BASS CLUB [Boston Audio Stereo & Social Club]
    • Second Time Sound - Audio Gear Re-Purposed
PeachTree Nova 125se - Integrated Amp / DAC / Headphone Amp
• 125 watts x 2 channels into 8 ohms (20-20,000 Hz) at 0.5% THD
• 200 watts x 2 channels into 4 ohms (20-20,000 Hz) at 0.5% THD
• hybrid vacuum tube/solid-state design
• vacuum tube preamp stage (uses a single 6N1P triode input tube) can be switched in to add warmth and smooth the jagged waveforms of highly compressed digital sources
• discrete Class A preamp offers fine detail and accurate signal transmission
• high-current, energy-efficient Class D solid state power amp
• built-in high-resolution ESS Sabre 24-bit/192kHz up-sampling digital-to-analog converter (DAC)
• galvanic isolation on all digital inputs blocks common sources of electrical noise
• built-in headphone amp drives demanding headphones with ease
• 6mm-thick brushed aluminum front-panel
• wood chassis
• digital audio inputs: 1 USB (Type B), 2 optical, and 1 coaxial
o supported sample rates: up to 24-bit/192kHz for USB and coaxial; up to 24-bit/96kHz for optical
• 1 pair of stereo RCA (AUX) inputs
• 1 pair of RCA audio preamp outputs (for connecting a powered subwoofer, outboard power amplifier, or using the nova125SE as a stand-alone DAC)
• 1/4" headphone output
• 12V trigger input enables power on/off control from external sources
• binding-post speaker connectors
• detachable AC power cord
• remote control
• 14-13/16"W x 5"H x 14-9/16"D
• weight: 17 lbs.
$645
Unit is in Excellent Working condition / Good cosmetic Condition with minor blemishes
Shipping within the Contiguous United States $65
« Last Edit: 8 Feb 2022, 01:26 pm by Bostown »
