$700 Record Vacuum for $10?
0 Members and 1 Guest are viewing this topic. Read 2277 times.
firewall
  • None
« on: 3 Feb 2022, 03:41 am »
Do you own a Dyson vacuum?
This device plugs into your vacuum - and vacuums your vinyl!
I was looking at $700+ devices. I looked at how they work and discovered that they are just glorified vacuum cleaners.
This works great! A HUGE difference - and it's only $10 on Amazon.
Now use the money you saved for an upgrade!
bkatbamna
Re: $700 Record Vacuum for $10?
« Reply #1 on: 3 Feb 2022, 04:37 am »
How do you use it(where does it hook up etc...) Is there a link, I couldn't find.
firewall
  • None
« Reply #2 on: 3 Feb 2022, 08:32 am »
Hi bkatbamna,
The right end (from the picture,) connects to your Dyson.
The left end has an anti-static type covering over the vacuum slit/hole.
https://www.amazon.com/gp/product/B08LKHYX8M/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
twitch54
« Reply #3 on: 3 Feb 2022, 03:47 pm »
Oh I can just see the messed up LP's right now, LOL !!
S Clark
« Reply #4 on: 3 Feb 2022, 04:47 pm »
Looks like it would be almost impossible to hold it steady enough to get a vacuum across the whole record, and even more impossible to hold it while the record rotated.
If you want clean records, buy or build an ultrasonic.
bkatbamna
« Reply #5 on: 3 Feb 2022, 06:00 pm »
I did find it on Amazon but currently unavailable.  thanks
mick wolfe
« Reply #6 on: 4 Feb 2022, 03:43 pm »
Or at least buy a vacuum based machine that's actually designed to properly clean records. I think you'll find the Record Doctor VI is cheaper than a Dyson. But it won't vacuum your carpet of course.
Elizabeth
« Reply #7 on: 4 Feb 2022, 06:08 pm »
I use my ordinary old Sears  vacuum with brush attachment to finish dry my records. I wash them in the kitchen sink. pat dry with paper towel then use the brush vacuum attachment to finish-suck the water from the grooves.
I think the fact of it being inexpensive violates some "Audiophile' fantasies.
Get over it.
Works great.
bkatbamna
« Reply #8 on: 4 Feb 2022, 06:20 pm »
It would be crazy to buy a vacuum cleaner just to use the attachment.  It only makes sense for someone like me who already bought the wife a Dyson for our anniversary a few years ago.
dflee
« Reply #9 on: 4 Feb 2022, 06:39 pm »
bkatbamna:
So what kind of room treatment are you using in the dog house?
Don
S Clark
« Reply #10 on: 4 Feb 2022, 06:48 pm »
Get over it.
Works great.
Vacuum systems do work great.  I've used a basic one for years.  But ultrasonics work considerably better, and they don't have to be expensive.  Use the two together, the ultrasonic to clean and the vacuum to dry, and I think your getting vinyl about as dust/dirt free as you can get.
twitch54
« Reply #11 on: 4 Feb 2022, 06:51 pm »
you bought your wife a vacuum cleaner for your anniversary ? is she still married to you ?   :scratch:
bkatbamna
« Reply #12 on: 4 Feb 2022, 11:33 pm »
Just joking about buying the vacuum cleaner for our anniversary.   :green:
tull skull
  • I can't send hare in search of anything!
« Reply #13 on: 5 Feb 2022, 03:23 am »
Thanks firewall for the suggestion. I am not sure of your experience but normal record cleaners are able to vacuum up a cleaning solution off the record. As in fluid. As in WET.
I am positive that the attachment is only designed for dry vacuuming. Vacuuming up moisture in your Dyson will definitely void the warranty.
I know you probably know this but just wanted to make sure.
veloceleste
« Reply #14 on: 5 Feb 2022, 11:28 am »
