Digital Amplifier Company, DAC DAC TL, (tube like)+ Cherry USB / SPDIF Convertor
0 Members and 1 Guest are viewing this topic. Read 574 times.
joessportster
  • Set & Single Driver Bliss
"WILL NOT SEPARATE THE PAIR" Sorry, You could buy both and sell what you dont need  :lol:
A Fully Balanced DAC in super shape this is the TL (Tube Like) version retail is (999.00) It is SPDIF ONLY I am including the Cherry USB / SPDIF Convertor (Retail 390.00)  Total retail was right at 1400.00...............SELL FOR 600.00 PLUS SHIPPING
Specs from Cherry site for convertor:
"Cherry USB is a low profile USB to coax SPDIF converter. It's a plug-and-play USB device (driver installation not necessary) for modern Windows and Mac PCs. Power is also provided through USB, so there's no need for an external power adapter. It supports sample rates up to 384kHz and up to 32 bit data. Can be used to drive any DAC with a coax SPDIF input, including the Cherry DAC DAC. Gold Neutrik RCA output connector. Slim case (just over one inch height) has the same footprint as Cherry Stereo Maraschino, Cherry 60V 1kW Maraschino Power Supply, and Cherry DAC DAC (any version), for easy "stacking". This USB converter also has anti-vibration Sorbothane feet. Comes with 6 foot high-speed USB 2.0 cable with gold plated connectors."
Specs for the DAC:
DAC DAC 1 TL - Tube Like Sound
Coax SPDIF input, PCM up to 192kHz sample rate, 24-bit resolution
External 12VDC power supply
Indicators for Power, Valid Signal, >50kHz Fs, >100kHz Fs
6.5" x 6.3" x 2.5" aluminum enclosure with vibration absorbing Sorbothane feet
No internal processors or fancy displays for low noise
DC Coupled Double Differential True Balanced XLR Outputs (RCA adapters available)
On board jitter removal
"In an attempt to make the audio signal path as short as possible, we designed an experimental output stage, and it sounded amazing! We listened for several hours in awe, then we measured the performance with an audio analyzer. To our surprise, THD+N wasn't so low as the input level rose toward full scale, but with the help of a low noise floor (120dB SNR), THD+N was pretty low as the input level decreased. "How is this possible?", we asked. "How can this thing sound so wonderful, but measure so-so?". Well, after taking a better look, we discovered that the distortion characteristics of our shortest-path circuit were similar to that of tube (a.k.a. valve) amplification circuits, providing a smooth, musical sound. We listened again to confirm this (loving every minute of it).... The Cherry DAC DAC TL (tube-like) was born!"
Price for the pair is 600.00 (Thats under 1/2 of the 1400 retail) This DAC sonics were a great surprise to me. It competes with newer DACs costing 4+ times the price. Only selling to off set the price of Audio Note 4.1x
Its small and light weight but it packs a huge punch above this price point
At my price I will cover fees and buyer covers shipping (wont be much as it is lite weight). Includes the 12VDC wall wart . The convertor is powered by the USB
Location is 28351 North Carolina, Paypal accepted, will Be double Boxed and fully insured
« Last Edit: 30 Jan 2022, 03:00 pm by joessportster »
