0 Members and 1 Guest are viewing this topic. Read 1509 times.
Allo also makes a $120 DAC+Amp (50W Tripath Class D amp), so then just add speakers and be done. This will also run Ropieee and be a Roon endpoint.Update: I meant to note that the prices above are for the kit from Allo with the case, power supply, microSD card, Raspberry Pi, and DAC (or DAC-Amp) depending on which you get. I'm not sure what would be less expensive, although it does get up to nearly $1000 for 7 of them. I'm not sure how much cheaper it will get, however.
I'm talking myself in adding some sound to a few rooms!
