Assembled weight of NX Otica / dual servo sub stack
0 Members and 1 Guest are viewing this topic. Read 789 times.
cjsailer
« on: 29 Jan 2022, 01:13 pm »
Using Don & Jay's flat packs, what would the approximate assembled weights be for these two kits?  The current audio rabbit hole I'm going down is isolating the speaker cabinets from wood floor.  I currently have cheap rubber feet and hoping to improve upon that.
Re: Assembled weight of NX Otica / dual servo sub stack
« Reply #1 on: 1 Feb 2022, 08:34 pm »
Each of the  finished Otica's  will be  aprrox   85lbs IIRC.
 Plan on  approx   125 lbs for each assembled  dual cabinet including drivers etc ( amps  separate)Triples  are  going to be  around  165 lbs per   assembled  tower.
jay
cjsailer
« Reply #2 on: 2 Feb 2022, 12:42 am »
Thank you sir!
