Chane SBE-118 Subwoofer & Chane 3600 Subwoofer Amplifier - $400 OBO - SOLD
0 Members and 1 Guest are viewing this topic. Read 821 times.
tortoiseman2542
Never Used Chane SBE-118 & 3600 amplifier combo.  Bought with intentions of using in new home, but housing market boom and Covid happened, so this never got used.
Amp is in pristine condition with no marks.  Sub does have marks from where the amp was shipped and stored on top of the sub (see pics).  This could easily be touched up as the paint used by Chane appears pretty basic wrinkle black.  Price adjusted accordingly but functionally it works perfect.  Amp could also be placed on top and you’d never notice.
Pickup only as this is VERY heavy.  Zip is 43016 for reference.  Specs of both listed below.
Robert
Sub Review and Specs
https://www.hometheatershack.com/threads/chane-3-2-home-theater-system-review.98073/
Amp Specs
Chane 3600 Specs:
19" two channel rack-mountable professional amplifier. Perfect for high-output subwoofer systems. Over fifty pounds of high current Class A/B audio amplifier not to be confused with cheap, 20-pound switching amplifiers with questionable ratings.
Two channels
Front panel level controls and power switch
Signal, protect, active, and clip/limiting LED indicators
Class A/B output stage
High current linear power supply
35# toroidal power transformer
Balanced inputs with pass-through
Speakon and standard output terminals
Adjustable high and low pass filters
Twin fan cooling
Rear panel fuse
Front and rear chassis rack ears
Painted steel
Rated Power, 8 ohms, 4 ohms, 2 ohms: 600W, 900W, 1100W
Rated Power, bridged mono, 8 ohms, 4 ohms: 1800W, 2000W
S/N Ratio: 105db
Slew Rate: 80V/us
Damping Factor: 500:1
Frequency Response: +/-0.1db,20Hz+20KHz
THD: ≦0.01% Rated power @8 ohms 1 kHz
IMD: ≦0.01% Rated power @8 ohms
Input Sensitivity: 0.775V, 1.0V, 1.55V
Low Pass Filter: 180Hz switchable
High Pass Filter: 130HZ switchable
Input Impedance: 10K/20K ohms, unbalanced or balanced
Common Mode Rejection Ratio: ≦-75dB
Crosstalk Attenuation: ≦-70dB
Power input: 115v/60Hz
Weight: 23kg, 50.5 lbs
Dimension: (mm) 483w × 490d × 88h, (in) 19w x 19.3d x 3.5h
« Last Edit: 2 Feb 2022, 07:01 am by tortoiseman2542 »
ServerAdmin
Please put back the asking price as clearly stated in the red box above and below your ad.
tortoiseman2542
Done!
Robert
