Stands for Davantis
0 Members and 1 Guest are viewing this topic. Read 713 times.
User456101
Stands for Davantis
« on: 23 Jan 2022, 02:55 am »
Bought a pair of Davantis now can figure out what stands will work. Never had bookshelf speakers before. How much of the bottom of the speaker should be supported? They aren’t diminutive speakers. A minimum of 6”x9” platform for the speaker to sit directly on or what? They are 13”x9-3/4” for the bottom dimensions. What has worked for others with the Davantis or similar sized speakers?
Danny Richie
Re: Stands for Davantis
« Reply #1 on: 3 Feb 2022, 02:52 pm »
Support as much as you can and use a heavy well supported stand that will get the tweeter to near ear level.
