Elekit 8600S with Lindahl Transformers and VCAP CuTF capacitors ***Sold***
0 Members and 1 Guest are viewing this topic. Read 655 times.
dcktr
Elekit TU-8600S 300B SET tube amp fully built
$2300 includes shipping to conus
Purchased Kit April 2021, Finished in Late May 2021. All voltage readings within specifications.
Selling because I went to fully active speakers (Soundfield Audio by AJ) and no longer need an amplifier
Minimal hours on the unit and tubes – probably 200 hours total.
upgrades: Lundahl Transformers, Takman Resistors, VCAP CuTF capacitors
Cossor 300B Black Plate (2)
Brimar 12AU7 (2),
Mullard ECC83, Genelex Gold Lion ECC83
Functionally is great – no problems -
Cosmetically: There is a small smudge mark visible in the close-up picture above the R of the word power. I never took the tube shield out of the package.
Rated output : 9.2W+9.2W ( THD 10% )
Rated input : 270mV
Residual noise : 36μV(IHF-A)
Frequency response :7Hz-40kHz(-3dB)
Input impedance : 50kΩ
Output impedance: 4-6.3Ω, 8-16Ω (Select by the SW on the rear)
Input terminal : RCA jack x 1
Output terminal: Speaker output Gold-plated screw terminal Banana plug
Headphone terminal :6.3mm headphone jack
Power voltage :AC115/230V 50/60Hz (3P inlet)
Power consumption :90W
Dimensions :W 385xH217xD325mm
Weight :Approx.30lb (excl. power cable)
« Last Edit: 29 Jan 2022, 12:16 am by dcktr »
dcktr
bump lower price
